- Joined
- Oct 22, 2017
- Messages
- 25
- Reaction score
- 9
Getting "Server Error" on 3CX Management Console when attempting to login since last night around 1:30AM Eastern Time.
Okay, I've restarted the VM Instance on Google and have now lost all access from Desktop phone and EVERYTHING, including no longer show the Management Console Login screen
Another observation; it seems that restarting the instance has given me a new public IP address. When I go to that address https://xxx.xxx.xxx.xxx, I get a dire looking warning (the certificate must not have this new IP address). I am now able to log in, but not with my FQDN, as it has a DNS record to the old IP.Rob Lifton, you basically just said what I should have said in the beginning. Great Summary!
I was having difficulty with trying to change from Ephemeral to Static.I was able to change the IP from ephemeral to static from the Google Cloud console. Too bad there isn't an option to update the IP and FQDN from the 3CX customer portal. I guess I will have to use one of my domains to name the VPS so that I won't need to change EVERYTHING if/when this occurs again.
Well, that's annoying - I created a DNS record with my domain registrar and changed my FQDN to that and some of it works (I can receive calls but not place calls). I had to go in and reconfigure my iOS softphone by hand and I can't see anything wrong, it just does not work.I was able to change the IP from ephemeral to static from the Google Cloud console. Too bad there isn't an option to update the IP and FQDN from the 3CX customer portal. I guess I will have to use one of my domains to name the VPS so that I won't need to change EVERYTHING if/when this occurs again.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
