Server Error Problem
abdallahessam
Dears,
I need your assist to resolve this issue as after rebooting my 3cx machine on ESXi I couldn't able to sign in again with the error "server error" however I didn't make any updates or changes, so I need a way to backup my data "specially recordings" to a new 3cx machine.
Second Point:-
When I connected to 3cx old machine through ssh and download my recordings and uploaded them to the new machine I received an error when downloading the recordings however the path is correct "/var/lib/3cxpbx/Instance1/Data/Recordings/" and system currently saves the new records on it but the old records "which I uploaded manually" isn't working even after restarting the machine and all services
As for this problem, you will need to change owner and group to phonesystem
Code:
chown -R phonesystem:phonesystem /var/lib/3cxpbx/Instance1/Data/Recordings/
Did you check all services have started up?
Code:
systemctl status 3CX*
Code:
sudo /usr/sbin/3CXStartServices
kieferschild Unfortuanlity,after restarting all services and also rebooting the machine nothing changed
What was the status of the services?
SnakeRiverWebDevelopment could you elaborate more on how to change owner and group to phonesystem as the mentioned command doesn't solve the issue
Did you use the ISO to install 3CX?
kieferschild sure i am using latest version of 3cx based on Debian
Ok cool.. next check if the nginx service is started.
Code:
service nginx status
Code:
service nginx start
you need to ssh as root into your system, then run the command, this will change the owner and group of all the recordings that were uploaded, if root is the owner than the pbx will not be able to access the files.
Code:
