SIP Trunk - Singapore - MyRepublic - UserAgent Header
PJJJJ
Hi All,
I am using 3cx Hosted Version 20 at the moment, I am facing an issue which SIP Trunk Outbound Parameter which is similar to thread below:
https://www.3cx.com/community/threads/user-agent-header.118207/
Unfortunately, I can't find Outbound parameter / User Agent settings with Version 20, SIp trunk registration & all incoming/outgoing calls are failed at the moment. I need help and advise how to change the setting with Version 20.
Thanks!
Did you managed to solve it?
It sounds that your are using an unsupported provider.
Have you tried to export the Sip Trunk, make the necessary adjustments and import the trunk back?
@TheodorosG_3CX, I believe due to local regulation therefore you don't have test account anymore. Incase 3CX is willing to subscribe, we can assist as we are partner with MyRepublic.
Can you please elaborate further? To which test account you are referring?
Regarding contacting our interop team for becoming a supported provider you may also contact us here.
lastshadow
