SMS Transfer to Queue
lthibx
SOHO User
It was stated in this post: https://www.3cx.com/community/threads/transfer-chat-to-queue.117651/
that the ability to transfer an SMS back to a Queue would be in V18 Update 6. We are now on V18 Update 8 (917). I have not found this feature or a way to do it. Has this not been implemented, and if not any word on when this will be available?
Hi, this is possible.
In your system go to settings — options and check it is disabled the parameter Hide System Extensions (IVR, RingGroup, Queues and FAX).
I tested and when transferring the chat the Queue extension is shown
Did anyone get this working, I haven't been able to make this work myself. That setting is disabled for me and I still am not able to find the ring group to enable transfer
Are you able to see the Transfer option?
Yes I am able to see the Transfer Option, however, when I click transfer, i can only select from user extensions and the ring groups are not available in the list to choose from
This will only happen if the option "Hide System Extensions (IVR, RingGroup, Queues and FAX) from 3CX Apps Company Phonebook" is enabled. If you create a new Ring Group for example and make a brand new test SMS, the issue is the same?
I have the setting you mentioned disabled and the transfer screen you see is showing user extensions only. Are there any other settings or permissions that control this type of functionality?
This happens for all extensions? Also did you test the scenario above?
Yes, tested with a new test ring group. When you say new text, I just sent a text message and then tried to transfer it, is that what you meant?
Yes correct. Can you please try to enabled, press OK, disable and press OK on the option to hide extensions?
I tried that and No change.
I have tried multiple times on multiple PBX's and did not have this issue.
I would suggest that you create a support ticket to check further.
rsaldin@advancedbrainspin
