Solved SNOM 300 STUN provisioning doesn't work
Goran Cvijanovic
I have built new PBX in AWS Lightsail, and everything except SNOM 300 phone is working good. I have added this phone to the new extension and I see that PBX successfully delivered configuration to RPS server, and when I go to web interface of the phone, I can see that phone received information from RPS server, but it's not able to provision and connect to the PBX for some unknown reason. This phone was previously connected to my home test 3cx via PnP and I also upgraded firmware to the latest and everything worked fine until now when I want to use this phone as a STUN extension. I rebooted phone to factory settings multiple times, and phone receives Server URL from RPS and locks down this field so I can't modify it.
Logs on the phone shows that phone is "Giving up" after some time, and provisioning URL which is used by phone is working when I open it from my PC that is located in the same LAN with phone.
Any advice would be appreciated.
Reactions: Goran Cvijanovic
I downloaded conf file manually and uploaded to the phone and it works. I will not waste more time on it, it's frustrating.
Thanks YiannisH_3CX!
Glad to see you were able to resolve the issue
Eagle Man
