Solved Snom D385/D785 directory empty after reboot
Dennis The Menace
Trial User
Dear List,
After having updated our Snom D385/D785 phones to the newest 3CX recommended firmware 10.1.54.13, on all phones, the directory shows <empty>.
After Maintenance -> Synchronize Settings, the directory is correctly loaded.
However after the next reboot/poweron, the directory is empty again.
PS: Everything worked correctly before.
Thanks for any help.
Dennis
Customers reported me the same issue on Snom M300 and call transfer is not possible anymore.
Is this a know issue too ?
Hi @Christophe Parisi
The M300 should not be affected, I can confirm that the device shows the contacts even after restarting.
To view the Company Contacts on the handset we press the right button (because it shows two directories - one for device contacts, one for company contacts)
Any update on this issue from 3CX?
Hello 3CX community,
We are very sorry for this inconvenience. The cause of the issue has already been identified, and our developers are working hard on the fix.
Unfortunately, there are sometimes issues that are not identified during the testing of a new firmware version. This shouldn't sound like an excuse. We constantly work on improving our test capacities, adding more and more test cases to avoid regressions.
Software bugs are always annoying, and we work closely with 3CX to resolve the problem as quickly as possible.
Mark
+1 here
same issue
Any news on this? The Webclient is completely unusable with this bug.
from phones view (admin panel), try to reprovisiong phones.
suddenly adressess re-appears.
workaround, of course, but it works.
but i've another bug, when i do reprovisioning on phone, logo disappear (snom D760).
How does this affect the Webclient for you?
It only affects dialling numbers from the Webclient that have a plus sign in front of them
when the Snom device is selected from the drop down menu as the default.
It is like JohnS_3CX said, dialing numbers starting with a + is not possible if you use the webclient with a Snom phone. If you have a missed call for example, you can't call the number back by clicking it. Or using numbers from a company phonebook, where all numbers are in the international E164 format.
@snomde
is there any news for a released fixed firmware?
@JohnS_3CX
Could it be easily doing on 3CX console to give admin a step back option with previous firmware when a problem like this one is revealed after you apply a new one?
Reactions: nitrox
@JohnS_3CX
I think this is a very good idea :)
@aws2p you already know there is the Ideas section, so I cannot comment here ;)
Anyway, you can downgrade your firmware on all the phones if you wish @mOrbo you can PM me and I can instruct you
IDEAS is out of my partner level privileges, so no way for me to ask as an idea
Never succeeded, each time PBX re apply alone the latest firmware
A downgrade would be interesting. But is there no danger that the new firmware will update itself again? So it happened with the 10.1.54.13 firmware.
But something has to happen quickly at Snom. I can also no longer hold up my customers.
Reactions: Marco Bohl
I found a workaround for the + problem:
In the Webclient, go to Settings -> General -> Other Options and check "Replace + with 00"
Adressbook and Call History are working again.
Snom has released a new firmware version which is now available on the 3CX updates page and will address the following issues:
1. Directory Missing
2. Cannot call numbers with + from webclient when choosing Snom phone
It should appear as an update on your PBX within the day
If you see this message later, the update may have already been downloaded by your PBX, please check your Phones tab for any devices appearing in red and you can deploy it from there for all Snom models that were affected
EMMEPICASA
