- Joined
- Dec 19, 2023
- Messages
- 38
- Reaction score
- 7
Hello, is it possible to use the same google cloud speech-to-text project for different call flows? Is it okay to use on two different CFDs?
Absolutely. But if they're for different customers, split them into different projects.Hello, is it possible to use the same google cloud speech-to-text project for different call flows? Is it okay to use on two different CFDs?
Okay, thank you very much! And yes it's for the same client, it's just that I intend to create two different call flows for off-hours and on-hours.Absolutely. But if they're for different customers, split them into different projects.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
