SSL certificate icssues ocaurs
Noeem
Dear Concern,
We have purchased a license key: (xxxx xxx xxx xx) (4SC) .
This license key was running with FQDN:xy.com. Today we can't reach PBX by this FQDN but can reach by Public IP.
And in PBX it shows "3CX Version 20 requires a secure connection to use the Web Client. You are not using an FQDN or HTTPS to connect to 3CX."
What can I do now to resolve this?
I'm looking forward to your urgent response please.
Hi @Noeem ,
As Paulo mentioned, from what we see here the SSL certificate did not renew automatically for some reason.
The next step would be for you to try and force the renewal, here you can find steps for windows as well:
Reactions: paulodagraca
backend is windows,
when i press double click in "PBXConfigTool.exe" then showing setup
You must run it from command line, not double-click, with the parameters shown:
PbxConfigTool.exe -renew-certificates
After change Temporary self file value 1 its showing https and opened for 10 to 20 min,then sometime leter again fqdn failed
Hello Noeem,
Can you check if there is a firewall that does block port 443 (for https)?
Is there anything in the 3CX "Event LOG" about the SSL renew?
Did you receive an email (send to owner), about the SSL renew?
Can you Click on the Lock icon in front of the URL in the browser, and check the status of the Certificate?
Do you have the correct FQDN there, is the certificate still valid or old?
Paulo
Firewall checked- there is no port block
Enent LOG = no any SSL renew msg coming
No any recive email to=owner
After changes value(Tempoo value1)= showned https success
yes=fqdn is correct
waiting for answer....
@Noeem, If you are unable to access via FQDN, you must verify your split DNS configuration.
Hi Noeem,
This is not normall so I am not sure what is wrong.
When the 3CX does a renew of SSL then it should send an email good/failed... no email means, the 3CX did not try ???
But again, you should make sure the option "TEMPORARY_SELF_SIGNED_CERTIFICATE_GENERATED" in the 3CX should still be set to 1.
And activate the SSL renew by enter the command in the CMD of windows -> "C:\Program Files\3CX Phone System\Bin\PbxConfigTool.exe" -renew-certificates
Strange this does all not work ????
Paulo
Finally we setup new one from fqdn release
So you did:
Backup 3CX server
FQDN release from 3CX Portal
Restore backup creating 'new' FQDN with same License.
Something like this?
Paulo
@paulodagraca ,,
paulodagraca , updated backup did not storage, so creating new conf from existing fqdn.​
lukas1103
