Solved SSL Error
miharrison
We recently migrated from an Azure Instance to 3CX hosting.
After chosing reinstall and selecting the backup we are recieving SSL error on machines.
Any ideas?
@miharrison as we can see from the hosted by 3cx pbx there is no issue.
Now at your side if you do an nslookup of the fqdn if the pbx, does this point to the old IP address you had in azure ?
If so, clear your local dns cache and open it in an incognito window.
Waiting for your feedback.
GP Concepts
