STOPTIME variable in fax template?
mobilowa
Forum User
Since I upgraded the 3CX Server to Build 18.0.4.965 from Build 18.0.3.461
3CX is not providing correct value for %%STOPTIME%% variable within the FAX Template when it generated e-mail notification for received FAX and FAX as PDF attachment .
in the email Notifications
%%STARTTIME%% and %%STOPTIME%% both variable give same value, indeed %%STOPTIME%% gives the same value of %%STARTTIME%%
It is supposed to be
%%STARTTIME%% date/ time of start receiving FAX
%%STOPTIME%% date/ time of finish receiving FAX
But after the upgrade
%%STOPTIME%% also just date/ time of start receiving FAX
Could you please assist how to fix and make sure %%STOPTIME%% provides time of finish receiving FAX ?
Thanks a lot.
Rich Hopkins
