T53 Firmware 96.86.100.5 DND sync with 3CX issue
gygo3122
SOHO User
Have latest self-hosted 3cx v18.5.build418 , but also installed new yealink firmware update for phones 96.86.100.5
Prior to update the DND button on phone ,when pressed ( phone shows DND symbol ), would reflect Do Not Disturb DND on under 3cx management console User->ext xxx->status
Also if you changed the status within the 3cx management console user->ext xxx->status then the provisioned yealink phone would show DND.
After the update this does not happen. Press DND on phone --- There is NO synced DND status in the 3cx management.
And the same in reverse.
In otherwords - pressing DND on the phone does not put change the phone status to DND in the 3cx console , and so no forwarding rules that depend on DND status will work.
You can manually set DND in the 3cx console and forwarding rules will work; but the phone does not display it is in DND mode;
Reactions: accentlogic
Kindly follow this post. The same issue affects the behavior you mentioned, and you will be notified in that post when it gets solved.
cur_cb
