Tech Support Portal
Drain Bamaged
Just entered a Tech Support Ticket. It's asking me to define what version I am using and there are no v20 selections.
Is this holding up my ticket from being processed? I suspect entering the wrong values will result in the ticket being misrouted.
Advice would be appreciated.
If you are asked for the version, choose Windows or Linux, depending on the OS where 3cx is installed; once the ticket is opened, the correct version will auto-populate in another section.
Reactions: IrinaP_3CX
