Transferring Calls from iOS or Android issue
MarcA
Running on: 18.0 (Build 35)
IOS: 20.0.10.76
This morning, we have noticed that transferring calls using the name/extension picker is not available. When pressing the transfer button, it shows the number pad and have a back arrow on the top left. When selecting that arrow, it shows the picker. When selecting an extension from the picker, it does not transfer the call to the selected extension. It makes another separate call. The only way to transfer is to manually enter the extension of the user.
Thank you so much! that worked.
circusduck
