Unable to activate licence maintenance
sohc
My maintenance license has expired. My reseller have confirmed that the license has been renewed.
I have tried changing the DNS, flush the DNS, restart the server but still no luck.
Can I get any advise? - I have a feeling that the license is still not active on 3cx end.
Hi @sohc,
Just confirming, what version of 3CX are you running?
Anything below Verison 15.5 SP6 will no longer activate no matter the Licence status.
Reactions: YiannisH_3CX
That explains it - I have version 15.0.59381.
I hold the upgrade because when I was in the previous version everything was working fine such as the template etc. Upgrading to 15 caused a lot of issues which is why I opted not to update anything again.
Also curious that your reseller didn't advise you of that fact that you needed to be on SP6.
Version 14 -> Verison 15 was a big change, so I can understand the reservations.
Since V15 the interface and provisioning has remained similar, so you should be ok to upgrade to the latest.
Follow the link @cobaltit provided for the simplest way to update, just be mindful of the Port Forward changes which came in to effect with 15.5 SP5 - https://www.3cx.com/docs/ports/
jmarshall
