Unable to forward a call from extension to ring group
nicojmb2
I'm trying to configure an extension to transfer a call to a ring group after 20 seconds.
Following this documentation: https://www.3cx.es/manual-usuario/desvio-llamada/, it indicates that I should select "system extension," but the ring groups don't appear.
What am I doing wrong?
Attached is a screenshot.
Is the Ring Group part of the same department as the user, or it's department is publishing extensions globally?
Yes, both are in the same department
Go to System -> Options -> Apps and make sure Hide System Extensions is not selected.
Reactions: nicojmb2
Hello nicojmb2,
Can you check the following option(s).
Paulo
Great, by unchecking this option the ringing groups now appear.
Graham Robertson
