Update 3 ALPHA. The Admin Timesaver
Great update! expecting stable final version U3.
Reactions: N_G and nikolascx
After updating to Alpha version today morning, I am facing issues with call connection with generic SIP trunk.
Calls get's disconnected within one second and get's error in activity log. In the report section it's showing no route exists message. Before upgrade it was working fine. Please assist.
08/12/2024 5:35:05.075 PM: Failed to create outbound lines to call +254********
Is it only with this trunk?
Do you have available ports on the server?
Can you check outbound rules? Maybe something is missing.
These are the things I would check first..
Looking like crazy, but where can i find: "More scripts are coming and these will be available via the Store button inside the Call Routing configuration dialog."
Thanks! How long can you look over feelds ;-)
Hope this wil get the on department option aswel. Have a customer that has a webshop with different Office Holidays but has different phonenumbers on the same sip-trunk.
We will work on this.. Can be done in the C# Code.. Feature noted.. We agree with this..
hey@nikolascx
I did the update (Version 20.0 Update 3 (Build 659 Alpha))
My call scripts page does not look like yours see picture
Reactions: nikolascx
hey@nikolascx
Create an empty script using that dialog, then you'll see the other screen.
Great update! Does this release also install any latest Debian patches? Thanks!
For those slow like me. To see the built-in call scripts, you have to create a new call script and then click on "GET FROM STORE"
Reactions: nikolascx and N_G
One other thing I've never seen discussed, which is an amazing addition that I'm not sure if others have noticed.
I found recently when you connect an IP phone and are on the same LAN. You can click the link in the IP phone area of the user and this goes straight to that IP phone and logs in to the web interface of the IP phone.
Also, is there any future thought in adding more storage options like AWS S3 etc?
I would like to express my appreciation for the recent 3CX V20 Update 3, it is indeed fantastic. However, I hope that the Extension Range / Group feature in call reports will be reinstated in a future update.
Thank you for considering this request.
hey@nikolascx
Click Next and you will find the next dialog. (my screen shows an already created script)
Yes we have plans for this.. It should allow you to create less reports.. Working on it. This will allow you to create less reports with more information.
Are the reports with graphs coming back?
Há algumas coisas nesta versão que ainda não consegui localizar. Por exemplo, no V18 era possível ter os backups sendo apontados para o Goolge Cloud e como gravados para o Sharepoint, agora em storage não localizei onde apontamos backups para o google cloud e como gravados para o Sharepoint.
Pelo que entendi só tenho a opção de apontar para um único local, quando anteriormente era possível apontar de forma separada .
Também achei um pouco confuso as regras de entrada antes pela regra de entrada consegui ver de forma fácil todas as entradas agora ficou bem confuso.
MDBW_Reif
