Update issues
newavealex
Forum User
hi
When I update 3CX Server 16.0.4.493 to 16.0.4.504
The system has not been updated successfully for several hours, I used to restart the server once
The system sent me an update fail email
However, I pressed Update again, and there is still no response. How do I know if the update will proceed or whether the update is successful...
this is my server log
Best bet would be to take the backup you made before the update (you did do that right?) and then uninstall 3CX and then do a fresh install and restore. Make sure to copy the backup outside of the 3CX backup folder before you uninstall.
Are you using some kind of antivirus program on that server or perhaps running any 3rd party software that may perhaps be accessing the 3CX folders and content?
2020/07/02 10:41:11.748|0006| System.UnauthorizedAccessException: Access to the path 'C:\ProgramData\3CX\Rollback\AppData\Data\Http\wwwroot\Recording\Syncfolders_Database_db' is denied.
Wecare_ITA
