User without access to the company directory
Alle CTEC
A customer asks me to set up a user who cannot see the company address book?
You cant...
Hello Alle CTEC,
You could block this on a hardphone (disable xml download), but I would guess that you do mean also the WebClient and smartphone APP, where this can not be 'disabled' on 'per user base'.
See answer bitn2.
Paulo
think you'll have to wait for unique address books per company in MCM.
Is it not possible to use a compatible SIP client smartphone application?
of course, 3CX uses SIP standards.
Ok but internally it works because you use the 5060, but externally when the smartphone leaves the company
If you allow unsecure/non-tunnel connections you can connect - you will need to evaluate the risk associated with any convenience.
Utilizzando la multiazienda non è possibile tramite la nuova funzionalità rubrica di reparto?
Alphabetic has already mentioned this.
"think you'll have to wait for unique address books per company in MCM."
Sorry, I missed your reply.
Ok so the only solution would be to create a 3cx instance for these users and enable a trunk bridge between the 2 switchboards so the second new 3cx needs a license it can't be Free
https://www.3cx.com/blog/releases/v20u8-ai-receptionist/
Department/Multi Tenant Phonebook​
In addition to the company wide phonebook, you can now have a separate phonebook for each department. If you’re running a multi tenant edition of 3CX then this department phonebook will be the company phonebook for the tenant. The department phonebook is available from the apps and the client and will be used for contact matching as well.
Not just for MCM. This is still in alpha but the way I imagine it, you'll be able to put the company phonebook contacts into a department phonebook instead, have everyone in the company in that department except that one extension which you can put in a different department.
Then that extension wouldn't be able to see the phonebook. It's still in development, there might be some limitations but I think it's the best chance of achieving what you want to do here.
Reactions: paulodagraca
Thanks everyone, I only have 2 last questions: a release date for the stable release 8? Is an Enterprise license required to use Multi-Company?
I don't know the release date sorry, also looking forward to stable. But no you don't need Enterprise for Multi-Company.
And just in case it wasn't clear you don't need to switch to Multi-Company to use the department address book - in fact I think your requirement of blocking one extension from viewing the phonebook wouldn't work in MCM anyway since departments are completely isolated from each other in MCM.
Reactions: KyriacosS_3CX
DrunkeMeister
