v16.0.2.910 Instance Manager missing
dandenson
SOHO User
I have one install where the instance manager is missing from settings. Can't seem to find any other examples on this.
This is an install on a raspberry pi3 btw, if that has any bearing.
should have used "Stock Debian" over Linux
raspbian |= Debian
so no it is not showing there
Then what does this mean?
Raspbian ≠ Debian
Because it is a customized version of Debian for the Pi and not everything is the same as stock Debian
To clarify:
  • Instance manager is available only on the PC Debian version, and not on Raspberry
  • Not on Windows
  • Not on anything less than V16
  • Not on Hosting Admin configured instances
  • Not on Failover instances
@JohnS_3CX that's a perfectly fine statement.
raspbian |= Debian
there is nothing odd, for PI there is no instance manager, nor on windows.
Here is my issue. Is the problem that raspbian isn't debian, or that it's a Pi period. Will I waste a bunch of time installing stock debian on the Pi just to find out that it's the ARM platform that isn't supported in instance manager, or is it raspbian that is the problem?
The quoted text is ambiguous and in that ambiguity it's contradictory.
If it's a raspbian issue, then why is the official documentation telling me to install raspbian lite instead of debian?
Hope you can see my point here.
bosdorf
