V20 3CX Not Responding to 183 Session Progress
krossh
We recently upgraded some of our versions to V20 as the deadline is coming around next month. Has anyone else had any issues with 183 early media?
Extension Dials (XXX) XXX-XXXX as 10 digit, This being a LD call should be dialed as 11.
---------V20----------
-Send SIP 183 Session Progress to 3CX PBX
-PBX receives this 183
-early media sent to PBX on V20 for misdialed number (dialed 10 digit, needed 11)
-PBX does not respond to 183
-Calling extension gets default hold music for roughly 5 seconds
-Call Terminates from the SIP trunk side for no response from 3CX
We ARE the SIP trunk provider in this case as well , which the configuration was working with V18 perfectly prior to this upgrade.
Ever since the upgrade to V20 this has been a huge failure point for this version.
We have attempted to open support tickets with 3CX but were turned away, even though nothing on our end has changed in the signaling, and we are the opps. support on the SIP trunk side as well.
ANYONE else seen this issue? and if so any recommendations?
apbGroup
