Solved V20 Missing Parameters
SweetDeaon
Platinum Partner
Hello
I wonder if anyone can tell me where i can find the registration ID and password of the 3CX App in the V20
they use to look like this
In V20 you can add a phone in your extension, but select this option and you will be able to see them
Yes but the default ID and password still missing. And, to the best off my knolage those are used by DECT phones to register in the system.
So, again, where i can find them?
I'm not sure what you mean by they are missing:
If you select "I will configure the phone myself" like I mentioned, you will see them on the final screen:
And for supported DECT phones, they will automatically load those parameters from 3CX provisioning.
It works
Thank you
Reactions: JohnS_3CX
Carlos - EC Mates
