V20 Unable to Make Calls
outland
Testing v20 and I am unable to make extension to extension calls. Unable to make outbound calls, Inbound calls do not register in the call log yet it appears I am getting to the system. Here is an example event log of an extension to extension call -
Level
Warning
Event ID
30051
Date & Time
11/29/2023 9:54 PM
Details
Unidentified Incoming Call. Review INVITE and adjust source identification:INVITE sip:[email protected]:5060;transport=UDP;tag3cx=zucr8qzq SIP/2.0Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-524287-2---PjFQZBeQVS9nu..b52nOvkyY9exM0Htuzb;rport=5080Via: SIP/2.0/UDP 174.207.160.72:2688;branch=z9hG4bK-524287-1---tunneltid;rport;tnlid=clnt.0-7ahuywiq5yppdo1f7lzqdwyxcus1h.iz_21844635Via: SIP/2.0/TCP 127.0.0.1:50195;rport;branch=z9hG4bKPjFQZBeQVS9nu..b52nOvkyY9exM0Htuzb;aliasMax-Forwards: 69Record-Route: <sip:[email protected]:5080;user=proxy;uri=clnt.0-7ahuywiq5yppdo1f7lzqdwyxcus1h.iz_21844635>Contact: "Brian"<sip:[email protected]:5060;rinstance=0-7ahuywiq5yppdo1f7lzqdwyxcus1h.iz>To: <sip:[email protected];tag3cx=zucr8qzq>From: "Brian" <sip:[email protected]>;tag=d8iOlypI2MdG5xk2ID326hmDVnY9nbOJCall-ID: fmnDWGww2FUyYuHS7h4ZDUSD9Oj.EfY5CSeq: 23504 INVITESession-Expires: 1800Min-SE: 90Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONSContent-Type: application/sdpSupported: replaces, 100rel, timer, norefersubUser-Agent: 3CXPhone for iOS 18.6.5.694Content-Length: 445v=0o=- 3910301678 3910301678 IN IP4 100.85.213.133s=pjmediab=AS:117t=0 0a=X-nat:0m=audio 10000 RTP/AVP 18 9 0 8 125 101c=IN IP4 100.85.213.133b=TIAS:96000b=AS:117a=rtcp:10001a=sendrecva=rtpmap:18 G729/8000a=rtpmap:9 G722/8000a=rtpmap:0 PCMU/8000a=rtpmap:8 PCMA/8000a=rtpmap:125 opus/48000/2a=fmtp:125 useinbandfec=1a=rtpmap:101 telephone-event/8000a=fmtp:101 0-15m=video 0 RTP/AVP 31c=IN IP4 127.0.0.1
Any thoughts or suggestions? I am using SIPTrunk.com as the provider. Thanks in advance
I can confirm Bridges work between V18 and V20 if it was configured prior to upgrade to V20, currently in V20 I have not found a visible way to add a Bridge in V20 short of using something on the backend or perhaps CFD.
Level
Warning
Event ID
30051
Date & Time
11/29/2023 9:54 PM
Details
There is an issue with your certificate first of all, there afe no intermidate and root certificates for ythe CA
As a first step fix this then continue onwards.
What I was attempting was a test importing a backup from v18 (everything BUT license, FQDN & conference). This was a fresh install of v20 with a new FQDN. I see now that some data carried over (<sip:[email protected]>). I don't know why this is though. @Charles_3CX, this is what you were referring to. I am hoping to get this worked out so I can prepare to migrate my other installs.
Senergia
