V20 upgrade result
anthony.labrador
Hello Community,
I'd like to ask, after the upgrade to v20. I observed that dashboard from previous version is not displayed same to the v20 new dashboard.
Previous version of Dashboard.
Sorry for posting the example Management console dashboard where I get this to google image search since I can't post our dashboard environment here.
Management consolde dashboard is different from the v20 dashboard.
I need to know. In the v20 is it was replaced?
Thank you community.
Yes, v20 merges the admin console into the Webclient. Login on the Webclient (no need for /webclient anymore either) using a System Owner (required for the upgrade) and you'll see the Admin section bottom-left.
Hello @ConceptsWeb,
Thanks for this info, and how about the graph? like the image shown I posted?
Do you mean the graph from the Management Console is not available in the v20?
tbf did you ever really look at that? it must have been using some resources duplicating what the OS can do.
Only thing I miss from the front page is the "number of calls in use" view. Was good for testing.
It is not.
Hi, still confused and still looking for the dashboard where in I can see the graph percentage like CPU Usage, Memory usage, etc..
Here is mine after Upgrade to v20, I need help if this is the new look of v20 upgrade?
That is gone.
I think theres a few hyperlinks in system health you can get text based info. apart from that, i guess thats the OS's job now.
There are not graph anymore. They may add them in a future update (v20 is still beta/RC.)
However, you can view most information via the System Health links in the right column.
Reactions: anthony.labrador
That is gone.
Yes, I already saw it the text based like a report.
So I confirmed from the community that the dashboard system health status graph like cpu, memory utilization is gone in v20 and I'm on the right track executing the upgrade.
Thanks, big help!
Agree on the "Number of calls in use" items now missing. Not really a fan of this new integrated admin page because I have always separated myself from my administration account so now I need to be logged into two different accounts or make my personal extension an administrator too.
If you click on Services, you can get a quick glance on the total CPU/RAM usage in V20.
VOIPEric
