V20 - When to update
Felixcat
I have an on premise V18 instal on Windows 4SC with a free license which expires 02.03.24. The license with expire unless I upgrade to V20 but I see posts saying V20 won’t be released for a few weeks potentially after 02.03.24. Will the free license be extended or should I upgrade to V20 RC3?
Thanks to all at 3CX for all your hard work on a fantastic product!
Thanks for your advice, do I just hit the upgrade button on the 'Your 3CX Page' as in the screenshot? I have split DNS set up plus hopefully all the other pre-requisites. Thanks for your help!
No thats to upgrade your license.
if its on premise you will log in to 3CX management console and do the update from there.
Thanks again, I don't see the update to V20 button on my Updates page, it just says my system is up to date. I have checked for updates but nothing appears....any ideas?
Are you on Windows? To upgrade to v20 it'll be a backup, uninstall, install. Debian you can update within the mgmt console.
Yes on Windows OK I will follow that process thanks again for your valuable help!
Have a check first im not sure theres a windows installer yet.
I think you're right, just been poking about and can only find V18. I guess if one isn't released by 02.03.24 I'll have to buy a license and keep V18 going for a while longer. Could you sell me a license in that case?
sure but i think they'll either release it by then or let you stay free until they've got the windows installer.
awan05
