Vcard and extension
keven.bernier
Intermediate Cert.
Good morning
I encounter a problem when using the 3CX phone app. I have contacts with extensions: example 418-789-6536, 129. My problem is that the comma is not supported by my PBX. How do you succeed that my Vcard is well taken into account by my PBX
Thank you
Good morning
Thank you
comma not supported? do you use 3CX PBX or only the app with another PBX?
3CX supports comma as pause.
Sorry Frederick
You are right
I’ll get used to it.
I actually use the 3CX PBX with the 3CX application on Iphone
I have version 16.0 and I host my 3CX
I receive this error on the PBX: [Flow] Target endpoint for +number,311 can not be built!
My voip provider is voicemeup
Thank You
Sorry Frederick
You are right
Thank You
I just tested on my app and PBX and can confirm that issue.
@NickD_3CX @JohnS_3CX any ideas?
The app should strip the dash character so 1-800-555 becomes 1800555.
Check your logs though, you said you see : PBX: [Flow] Target endpoint for +number,311 can not be built!
Is the number you see there in a format that the provider accepts, and do you have an outgoing rule that allows that number to be dialled out? The comma cannot be used and needs to be removed by stripping it out.
Use your sip trunk settings Caller Id section, and replace them at outbound
bosdorf
