Visibility of associated queues from the extension (via the administration console)
Jrm95
Platinum Partner
It is currently very difficult for a manager to see/modify the queues to which an extension is attached.
Would it be possible, as for the Direct Inbound Dialing (DID) part, to have a queue view to be able to check/modify/delete/add queues to a user?
You should post in the ideas.
x1515
