Voicemail for Holidays
meyerf
Forum User
Hello
I want to know if it's possible to configure Holidays with Voicemail options?
I did not found any options, maybe you can help me.
Cheers,
Flavio
You can modify default IVR HOL and send call to voicemail
Hello @meyerf
Do you mean holidays for the entire system or holidays for specific extensions?
Hello YiannisH_3CX
I mean both. Is it possible to send the calls during the holiday directly to the IVR HOL or do you have another option. It would be great if I can automate this process.
Cheers,
Flavio
When a holiday is triggered the 3CX will go into out of office hours. If the option "Play holiday prompt when it's a global holiday " under your trunk settings is enabled then all calls will be diverted to the HOL IVR. If not then calls will follow the Out of office hours destination.
Thanks for this tip. That looks not bad, I will try it tonight :)
Reactions: YiannisH_3CX
Call_Flow.co.uk
