VoiceMail problem after upgrading to V16
akjon RooSho
I'm having problem after updating my 3CX from V15 to V16.
When I'm dialing 666 for the voicemail menu, I don't listen to the greeting message there.
When I try the built in voice mail button on 3CX softphone menu. I can see the voicemails there but when i click to play after receiving the call from playfile I don't listen anything on my phone.
But when someone calls me and the call is forwarded to my voicemail he/she can listen to the voicemail greeting that I put there.
I've not changed anything into my router after the upgrade.
Did someone face something like this? Can someone help me here?
Regards.
3CX V16 is Alpha so shouldn't be used other than for testing purposes.
Hello @akjon RooSho
As mentioned by @Lee Cramman V16 is an Alpha version and should not be used in production environments. Having said that what phone are you using? Have you tried the same from a client in softphone mode? What happens if you call the voicemail of a different extension, do you hear their voicemail prompt?
I should have taken considered it. My Bad.... :confused:
Hello @akjon RooSho
Yes, I've also tried that. I still don't get any voice.... :(
Is there any way I can downgrade?
Ok so others can hear your prompt but your extension does not hear any prompts. Correct?
If you have a backup of the previous version you can un-install V16 and install V15.5 using your backup. If you do not have a backup then you cannot downgrade.
Before doing anything however, try upgrading to V16 Alpha 2 which was released today and see if that fixes your issue.
FYI We tried a downgrade using the restore backup and did not go well.
You mean a backup from V16 imported to V15.5? If so then i am not surprised as backups from newer versions should not be used to restore previous versions of the PBX.
of course not Yiannish!
Did you get an error when trying to restore the backup? What do you mean by it did not go well?
mjwhyman
