"Voip Innovations" SIP Trunk missing
marloweforum
I have the latest version of 3CX, I just downloaded it yet under US -> Voip Innovations does not exist.
Why wouldn't it exist if it's a supported provider and what do I have to do to get it to appear?
13226
Latest released version (Update 3) or alpha version (Update 4). Are there trunk updates available?
It was a fresh install -- Who would have thought to run an update immediately. I just did that, all is good now. Thanks for pointing out the obvious!
No problem. Option B was going to be get your trunks from us ;)
Hi @marloweforum
Please state your exact PBX version, whether you have installed any pending updates in the Updates section, and what browser you are using when this occurred.
Hello @marloweforum
Check your Updates section of the PBX. You should see VoIP Innovations available for download.
Wecare_ITA
