Welcome Mails don't send - SMTP Test OK
Sommer
Intermediate Cert.
Hello everybody.
Our customer has 3CX V15.5 on Debian and uses the 3CX-SMTP Server.
When sending a testmail from the settings, the mail is sent and recieved without problems. Also mails regarding missed calls are being sent and recieved.
Only welcome-emails don't get recieved - how can I check if they are even sent?
I tried it with different adresses of different mailservers, of whom recieve welcome-mails from other 3CX-installs without problems, yet they don't get the welcome-emails from that particular 3CX install.
Any ideas?
Thank you very much.
Best regards,
Sommer
Hello @Sommer
Since only the welcome emails do not get sent i would recommend checking the welcome email template and making sure that you are using the default one without any changes.
You can check if there is a custom template by navigating to Settings / Parameters and search for "MAILTEMPLATE_EXTWELCOME_CUSTOM". If there is a custom welcome email delete it, restart the management console service and try again.
Hello YiannisH.
There isn't a custome template. After further investigation I think they have a problem with their very strict network setup.
Thanks anyway.
Best regards
Reactions: YiannisH_3CX
GothamUser
