What are MacOS users supposed to be doing now?
paulsummers
Things seem a bit quiet on the MacOS client situation. Still feeling really let down here 3CX! We have 35+ people really struggling to work effectively using the webclient dialer. I see there is a MacOS native app being developed? What is the ETA on this? I also see a recommendation to use the PWA client, but the installation instructions look nothing like instructions, there is no download option.
@biggreyphone I will send you a personal message to examine it further.
@biggreyphone
We have looked into this with the R&D Department and for some reason some M1 Max MacBooks are having this issue and we have not yet managed to identify the source of the problem.
Other M1 MacBooks though do not seem to have this problem which is a bit strange.
For the time being, if you are a M1 Max MacBook user having this problem, the recommendation is to use either the 3CX WebClient or PWA app until a solution is found for this.
@biggreyphone
Hi!
I have sent you a PM. Have a look at it and let me know how it goes.
Roman Mazur
