Yealink phone call history shows "Yesterday..."
Phill.
Not sure if anyone else has this issue as well but as i have set the phone system to the timezone of +10 GMT, if i look at calls in the morning before 10am, it shows the calls as "Yesterday xx:xx AM"
These phones (T42G) are configured with the latest firmware with no custom configs, and i've never had this issue prior to using 3CX.
Anyone know a fix for this?
I have already, restarted the server, re-provisioned phones and factory reset them.
It show's where? In the phone itself, in the call log in 3CX?
My guess is the call log ON the phone.
So you said you have the phone system set. Are you talking about the system time on the OS, the time in 3CX or the time on the extensions itself. I'm assuming you left the defaults with the system time set to -10 and the extension using the system default so I'm betting the OS time is off and needs to be set to -10 as well.
As the 3CX instance is setup on Debian, the timezone i set on 3CX is pushed to the OS. I just verified the OS time and its accurate to the correct timezone of +10.
The timezone on the phone is set to +10
fngl
