Solved Yealink T46G "MAKE CALL" from Windows CTI Client over SBC
Paul Ratcliffe
On our T46G phone that is located in a remote office, it is connected with a SBC. If we use the Windows CTI client to dial, it will ring the phone with "MAKE CALL" and will then only make the call when accepted. As this is a supported phone, the CTI client should just dial the phone if I am not mistaken without the need for "MAKE CALL". Have I overlooked a setting somewhere to enable this? Firmware and software updates are all completed.
UPDATE: All resolved.
Hi Paul,
Glad it was resolved. This is indeed supported and should work, so feel free to include your cause/solution if you want.
devo.it
