Yealink T54s DialNow
Justin Estruch
I was reading through a bunch of posts and searching online. Has anyone ever gotten Dial Now rules to work on a T54s or other models? Basically from what I've read online, it seems that the option to set the Dial Now download URL ( dialplan_dialnow.url ) is set by the common phone config file which in the case is y000000000070.cfg for the T54s. The problem is 3cx generates this on the fly so there is no way to edit this. I can confirm my phone is not receiving this option as when I go to Phones> select phone> Config , the dial now option is not there even though it is set in my custom template.
Any ideas on how to get this working?
Reactions: Justin Estruch
Thanks for the article! I actually just figured it out.
For future reference for anyone looking for this, by default the dialplan_dialnow.url is included in the common cfg part of the 3cx template. I simply moved this option to the beginning of the mac specific part of the template ( you can search for %%mac to find the beginning of the max specific part ) and viola it now works. I just have to work on getting port 69 open for tftp for our wan phones but all should be good as I've tested this on a local tftp server. Very confusing on why this option doesn't work when it is in the common area of the 3cx template.
sls1
