- Joined
- Aug 27, 2023
- Messages
- 5
- Reaction score
- 1
My client would like to disable the following four softkeys:
History
3cxPbook
DND
Menu
They'd also like to disable the functionality of the 'always forward' button on the bottom right of the phone, just above the speakerphone button.
It looks like a phone handset pointing to another phone handset.
They are concerned that buttons will accidentally get pressed when the cleaning crew clean the phones, and DND or the Menu is accessed by accident.
Earlier, I had posted how to disable the History feature, and the suggestion i was given does work... history shows empty which is great for this common area phone.
Now they just want to take it a step further.
thanks.
History
3cxPbook
DND
Menu
thanks.
