@YiannisH_3CX I am trying to follow your recommendation about checking 3cx logs.
Going under Dashboard - - > Activity Log - - > Filter by date does not work, it does not display any logs.
So, I picked the 3cx Bin Log Viewer approach.
I selected Support - - > Generate Support Info and downloaded the generated zip file.
Under the "Logs/" folder it includes indeed a "3cxPhoneSystem.bldef" file which can be imported in the Bin Log Viewer.
However, it does not include information about January 21st, when the issue happened.
For this scope, I have downloaded the ".3CXPhoneSystem-20190121-052106.
blrec" file which seems to include logs produced during the time of the issue.
Two questions please:
1. Why does the filter under Dashboard - - > Activity Log - - > Filter by date
not seem to work?
2. How can I import the Logs of the 21st of January into the Bin Log Viewer? I assume I need to correlate the blrec file of that date with the bldef file produced after the "generate support info", correct?
Thank you in advance,
George
