- Joined
- Sep 28, 2018
- Messages
- 1
- Reaction score
- 1
I need an integration with of 3cx Zoho CRM Phonebridge.
These task are important to me:
- Click to Call in Zoho CRM
- Call popup opens in Zoho CRM
- I can make a note and shedule a new call within Zoho CRM
- Call is saved in the Zoho Contact, that I just called
- Incoming calls open popup in Zoho CRM, show the Contact in Zoho CRM
The current integration https://www.3cx.com/docs/pbx-crm-integration-zoho/
is NOT saving calls in Zoho CRM contact and I cannot shedule a new call within Zoho CRM.
So I really need a solution with the Zoho Phonebridge Adapter.
Can I install the Zoho Elastix Phonebridge Adapter on a 3cx system?
https://www.zoho.com/crm/help/zoho-phonebridge/asterisk-avaya-elastix.html#Elastix
Will this work?
Do I need to have the 3cx software installed on my own server to install the Zoho Phonebridge Adapter?
http://zoho.com/crm/1549989/ZohoCRM_CTI_Adapter_1_1_for_Elastix1_6.zip
Or is it working with the google hosted version of 3cx as well?
Thanks for help.
Will this work?
Thanks for help.
