15.5 Update 1 (SP1) - Available Today!
MichaelB_3CX
3CX Team
Staff member
3CX Support
Update: V15.5 is no longer available. Download the latest version here. Following the BETA of V15.5 Update 1, the final release of this update is now available. The BETA was received extremely well and we appreciate all the feedback you provided! In the BETA we included: expanded IP Phone configuration options, easier configuration and troubleshoot...
Reactions: nb
Hi Nick, You are right!! sorry I didn't noticed that. Thank you for your feeback
possible bug... go into your voicemail and record your greeting. mess up your greeting and push 1 to re-record. the system will barf and dump you back to the menu. this also happens on recording your name option 5.
HI network 51
Thanks for your feedback
This has been replicated and we confirmed it as a bug. Thanks for reporting. We will fix this in the upcoming version.
Reactions: dcourtney
thanks really good job with delivering hotel module features in such a short time!
We did extensive testing and all works perfectly fine. There are two minor things though which are stopping us from upgrading our v14 hotel setups ->
1. missing option for e-mail notification on failed wake up call
- would it be possible to add this feature?
- or alternatively, we can write our own CFD project to handle the e-mail notifications. In that case, our idea is to forward failed wake up call from Wake-up DR into voice app enabled call queue. What we will need to achieve this is that Wake-UP DR sends info on which extension failed to answer the wake up call. Currently, when we forward the failed wake up into voice app enabled queue, the info on which extension failed is not passed
2. Maid status dial codes vs. audio file used to confirm the call
- currently, when maid status code is dialed from room phone, the call is confirmed with prompt "thankyou_goodbye.wav".
- would it be possible to change this on your end and use dedicated audio file located ...3CX\Instance1\Data\Ivr\Prompts\Hotel\ instead?
Reason I'm asking, in our setups, we are muting thankyou_goodbye.wav to avoid this prompt to be played when for example IVR hangs up call after playing prompt.... It would be really good to have option to use dedicated maid prompt same as v14
Other than these two, the hotel module and option to setup wake-ups via web client is really really good!
Reactions: nb
Thank you for your feedback.
Best go to the ideas section of the forum and post these in there as 2 separate ideas. (The one of the email notification on missed wake up call is already there i guess so you just need to vote for it.)
haytham
