3CX cmd to dial numbers
UserX
Hi all,
I've looked everywhere for a solution where we could use cmd to make calls in using 3CX Desktop App.
The closest i could come is using C:\Users\%username%\AppData\Local\Programs\3CXDesktopApp\app\3cxdesktopapp.exe tel:xxxxxxxxxxx but this onle places the number in the dial pad. We'd want it to make the call too.
Any idea?
It depends on what you are trying to do? why use a cmd to place the call for you? If you are trying to emulate a dialer then you could just create one using CFD.
Syedx91
