3cx CRM Server API
rsuren
https://www.3cx.com/blog/releases/phone-system-update/
3CX V15.5 Update 2 Final Release: Hot desking, CRM integration and more
one feature in above release is
  • Server based CRM integration – Learn more here
https://www.3cx.com/call-center/crm-integration/
when i go to link, there is nothing about server based 3rd party crm integration , only an window api is there which was there from old days, and no proper documention also .
how can i use a windows api in 3cx linux server ?, plus what was newly released in this build ?
Hello @Farhad Farahmand,
The file you downloaded contains the file "3CXObjectModel.2.0.0.0_v15.chm", which is a windows help file. Open it to navigate the API, you will see all the classes, methods and properties you have available to work with. The ZIP also has a folder named "OMSamples", which is a Visual Studio project showing how to use many of the features from the API.
You need to check all this information. Open the Visual Studio project and study the C# code to understand how you need to create your program.
Please note that we can't provide support for this API, so you're on your own...
Kind regards.
Maiwand
