3CX Email server not sending notifications after password reset or user creation ?
Kovacevic
SMB User
I have a On Prem Version 20 Update 9 installation, so far I didn't have any issues with receiving notifications from 3CX Email Server when I create a user or reset a password on one.
At the moment I an not able to receive a notification whatever I do.
Also when I try to do a test on the page where you can chose which email to use, I get an error Service temporary unavailable
Any ideas how to resolve this or 3CX has an issue?
Which license are you using? Using the 3CX SMTP service is not possible with the Free edition.
Hi, I know, I am using an AI edition with 16 parallel calls. It was working recently,
Does the firewall check complete successfully? Is the system time correct?
Interesting enough it was green, yet when I perform the test I get the following result:
Sounds like an dns problem.... its always dns ;-)
Seems so, I will check further in that direction. Vielen Dank für die Hilfe :)
Reactions: bitn2
IIRC if the license is set to the wrong IP, using 3CX SMTP isn’t allowed.
Reactions: bitn2
StevenWillems
