Automatically Route Incoming Calls to the Last Dialed Extension
blancers
Hello 3CX Community,
I'm looking for assistance with a call routing scenario in 3CX. Here’s what I’m aiming to achieve:
I have four extensions in my 3CX setup: 1001, 1002, 1003, and 1004. Suppose extension 1002 makes an outbound call to +1xxxyyyzzz. When +1xxxyyyzzz calls back next time, I want the call to be automatically routed to extension 1002 without any manual intervention or the use of an IVR.
In summary:
  • Extension 1002 calls +1xxxyyyzzz and completes the conversation.
  • On the next incoming call from +1xxxyyyzzz, the call should automatically route to extension 1002.
I’m not sure if this is a simple configuration or requires more advanced setup. Any suggestions or guidance on how to achieve this automatic routing would be greatly appreciated.
Thank you!
You are going down the correct path. A CFD application will be required. All inbound calls would need to be routed through this CFD. The CFD would need to query a database of previous calls to see who talked with the contact previously. You could get this information from the CDR file data. The CDR also includes the date/time of the call.
If the last call was within a reasonable timeframe, you could route the call back to the same agent, or if there is no previous call, or the call took place a long time ago, you would route calls to a default extension. However, you first need to consider (1) does that extension still exist, (2) is the person currently available? You don't want to send the caller to a user on vacation, or already on a phone call.
Obviously, to do this you need a way of parsing the CDR data into a database. Our 3CX Exporter tool can help with that step. If you need help with building the CFD application, we can help with that too.
We do it via the CRM integration and a simple CFD. DM us if interested.
Come on @ConceptsWeb, you are being too modest. To do this correctly, you need to look at agent availability, and expire the calls in case the last call was a year ago, etc. There is a lot involved in doing this correctly.
Good queries and few database triggers do the trick just fine. The CFD can take care of the rest upon being called.
I'm just trying to give you credit for having the expertise to make this work. It is not simple unless you know what you are doing, and maybe not even then.
ARKC
