BLF not showing on the PWA
Thegoldenaxe
Gold Partner
Hello everyone
For some reason the BLF panel is not showing in the PWA app or webclient.
Is there a configuration on seting that should be done for the panel appear ?
thank you
You may be running a version of 3CX that came before the feature was introduced.
Install V18 Update 7A and it should appear.
The 7.312 does not allow this feature?
Nope - this is the previous version that does not yet have the feature.
You will have to update to .424 and immediately after that you can install .441 to be on the latest version.
See changelog here if you want to know what else these updates have:
https://www.3cx.com/blog/change-log/phone-system-change-log/
Thank You for your help
Reactions: JohnS_3CX
jb_erp
