Call waiting on ring group
[email protected].
Forum User
I have a client only has one extension in the ring group. This client need to keep all incoming calls to be in a queue, if the extension is busy. while the extension is busy, they need to play a recording asking the caller to wait till the extension gets free. I have enabled multiple calls on this extension. But the incoming calls goes to voice mails after 20s, if the extension is busy. Can anyone give me a direction on how to meet this client requirement.
If you need to keep all incoming calls in a queue then setup a queue and route the calls to it? Not sure why you would setup a ring group if all the calls need to be in a queue.
Thanks for your reply. If a queue is created and extension is added, is it required the extension to log on to the queue everyday, or is it automatic.
extension if only one can stay loggedin and available all the time, you just need to set office hours to forward to OOH incoming traffic to a night IVR with message giving your working days and hours
Once you log in, you are logged in permanently unless something changes this like for example:
- Log out event (global log out / explicit log out)
- Status change
- Auto Switching
Please take a look at the link @cobaltit posted, and if you want a more in depth look also check out:
https://www.3cx.com/3cxacademy/videos/advanced/call-queues/
Could be likely his customer is on Standard edition if its only one extension - you'll need pro edition for queues.
Remember you need Pro or Ent license for queues
Thanks for the replies. Yes we are in Standard Edition. Now looking into getting pro version licence key. Hope once updated to Pro version, I can use the Queue function to meet the client need.
bosdorf
