Channel Limit problem
edbroaddus
I have two trunks setup. One with a limit of 3 (used for inbound calls only) and another with a limit of 4 (outbound calls only). When placing calls sometimes they get the channel limit message. Doesn't seem like either trunk is maxed out at the time.
07/11/2024 10:16:50 AM - Call to T:Line:10001>>1xxxxxxxxxx@[Dev:sip:[email protected]] from L:84.1[Extn:111] failed, cause: Cause: 600 Busy Everywhere (Channel Limit)/INVITE from 63.247.69.226:5060
07/11/2024 10:16:50 AM - [CM503003]: Call(C:84): Call to <sip:[email protected]:0> has failed; Cause: 600 Busy Everywhere (Channel Limit)/INVITE from 63.247.69.226:5060
07/11/2024 10:16:20 AM - Call to T:Line:10001>>1xxxxxxxxxx@[Dev:sip:[email protected]] from L:83.1[Extn:111] failed, cause: Cause: 600 Busy Everywhere (Channel Limit)/INVITE from 63.247.69.226:5060
07/11/2024 10:16:20 AM - [CM503003]: Call(C:83): Call to <sip:[email protected]:0> has failed; Cause: 600 Busy Everywhere (Channel Limit)/INVITE from 63.247.69.226:5060
SIP response is from your provider, you'll need to ask them.
Reactions: JohnS_3CX
I would normally agree but why am I even reaching the limit? We don't have 4 outbound calls active and all outbound rules are assigned to the outbound trunk only.
Did you assign any limits when setting up the trunks with your provider? As mentioned, the message is coming from them, not a 3CX limit message. Could be a routing issue that they are having.
Are the 7 trunks with the same provider? Perhaps here is a limit that is being applied to all 7 that was supposed to apply to only one "group".
Carlos - EC Mates
