Custom CRM Template Search Scenarios
bperry11
Trial User
I've been able to get a custom crm template working for CID lookup as well as basic search functionality. My issue is that my API only has firstname, lastname, email, etc.... and doesn't have a full name or freestyle search endpoint. So, if I search contacts and type in a first name results begin to appear (but not specific enough results), but as i put a space and beginning typing lastname it stops returning any results.
Presumably, "first last" doesn't match any first names or last names so nothing comes back. Can I work around this in the template? I've tried what I could think for splitting the searchtext and running multiple passes but haven't been able to get anything to work. I'm on a hosted 3cx so I don't have a way that I know of to look under the hood and see what's going on.
Is there a way to handle this to make the search functionality more usable?
Solution
I’ve tried to use Split() with the idea of having the multiple Scenarios. I don’t seem to be able to get it to parse correctly.
Would you mind sharing the syntax that works for that?
Something along the line of
[[SearchText].Split(' ').[0]]
I’m not
No.
Code:
[Split([SearchText]," ",0)]
Value, Separator, Index to return.
Create multiple scenarios all starting with "SearchContacts_" and do a search on one field per scenario. Results will be merged and 3CX does the splitting IIRC. If your API is custom, you can always add a column in your database for full name as well.
The problem is that they will need to split the search text, and then run the query with each text item. It's not a simple approach, actually I'm not sure it can be done at all. Maybe the simplest solution would be creating a proxy server, put it between 3CX and the CRM, so 3CX can send the query to this server with the full text, and then the proxy invokes the search of each word in each endpoint.
I usually set them up to use Split() with firstname,lastname basis for scenarios. It's not always perfect but then you can duplicate and have each split searched twice (once in each field), which accounts for FN,LN and LN,FN.
I’m not
I’m not
No.
Code:
Solution
Just for your reference on why this doesn't work:
You're using 2 consecutive C# expressions there. First the Split invocation on the string variable, and then the index operator. 3CX evaluates C# expressions, but one at a time. So the following will work and return a string array:
[[SearchText].Split(' ')]
Then you would need to surround all that in another expression, and invoke the special get_Item method that is used under the hood by C# to invoke the item property of an array:
[[[SearchText].Split(' ')].get_Item(0)]
So it's a bit tricky this way. The approach suggested by @Evolute IT is simpler. I'm describing this just for your reference in case you need something else that doesn't have a function provided by 3CX, like the Split in this case. This approach is more generic and will let you deal with C# array items in any other case.
@Evolute IT thank you for providing that. I was able to get results knowing that syntax.
@edossantos_sipcaller thank you for the explanation! That is super helpful.
In the end I ended up setting up a proxy to process the requests/results and handle the logic. Seems to be working good enough. Again, I appreciate the help!
Rich Hopkins
