Solved DECT base station Yealink W60B will not register
KraGwort
We had a working W60B base station with 2 W53H phones. One of the phones dropped and became unregistered. Worked on it for a while with no luck. Then the base station itself dropped to unregistered. Worked on that for a while with no luck. Deleted the base station from the system, reset the base to factory and re-added as a new device/added the provision address given by the system etc.. Confirmed the firmware for both the base and the phones is the latest offered at Yealink. I just cannot get the base to do something it needs to do. This base and phones are still listed as active by 3cx. They are EOL at Yealink. Any suggestions?
Reactions: DAndersonn@bis. itk
The device is indeed EOL but seems to work fine for the time being at least.
I got it working using firmware 77.85.0.180 on 3CX V20 Update 9. Since your system is Hosted by 3CX, you must configure the remote device behind an SBC for it to work (this is mandatory).
Ensure of course that the SBC is indeed online and working, and it's on the same LAN as the W60B.
I updated the firmware in the original round of repair attempts. Currently at 77.85.0.160. That is the highest version I can find on Yealink's website. 3cx system version is Version 20.0 Update 9 (Build 995 Release - AI 1.4.48). The SBC is currently version 18.1.36. Both are calling for updates that I have not done yet. Didn't want to confuse the issue with the DECT with updates.
When you specify the DECT needs to be behind the SBC, should the provision link point at the SBC? It is currently, and was before the problem, pointed at the 3cx server for this company.
Again, the DECT was working, then it wasn't with no known system or network changes.
Thanks for the help.
When adding a DECT phone from the PBX, after selecting the model and adding the MAC, you are prompted to choose the provisioning method, either local or via an SBC, as shown below. You should choose the SBC/Router Phone
Yes, that is what I used to add the device. Forgot the first line included SBC in the description.
If the SBC is malfunctioning as was suggested above, what would the symptoms be? Users are not reporting call issues. The SBC is showing online in the admin console.
If all phones are working normally and only the DECT is not provisioning, this would indicate an issue with the DECT. Please check with the vendor and install firmware version 77.85.0.180, as per John's reply, and try again.
Reactions: BrunoI_3CX
v180 is not listed on the Yealink site. Listings stop at v160. I put in a ticket asking about it. We will see if they answer.
Please do so and let us know
Not the main site, follow the links from our guide which bring you here: https://www.yealink.com/en/solution-detail/resource-for-3cx
Also, confirm that your SBC is indeed on the same LAN as the W60B like I said above. The SBC will not help if its not in the same LAN.
As for the SBC status, you can confirm it from the Voice & Chat page. It will be green, and if you click it you can even see the IP, statistics, etc.
Yealink came through last night before I saw the latest reply. They sent me the v180 file. I compared it to the file on the page you linked and are exactly the same size wise. Anyway I put that firmware in and no change.
This is a very small office. There are only 2 switches and a half dozen or so PCs and phones. The network is flat. Just a single vlan. I can ping both the DECT station and the SBC from my laptop. The IPs differ in the last .xxx number using a triple 255 mask. The SBC shows green in the admin console and the details look like I would suspect they should.
I did try removing and re-adding the DECT base again after the v180 firmware install. Are there any logs you can recommend I view? Something that would show the DECT trying to do what it needs to do and getting turned away.
Cool, you have everything in order so far. Now download the cfg file from 3CX and import it in the device:
I downloaded the file but am not on site at the moment to try it. Isn't the application of this file what happens when you run the provision now button on the auto provision tab? I did not see this step specified in the instructions when i added the Base to the system.
Doing as was specified above with the cfg file did not correct it.
Customer decided to buy a new base station. A new Yealink W70B. Same issue and same stop point. Both stations are communicating in that after the provisioning link is placed and the unit rebooted, I can see places where company specific links are added. Also the PW to the base is changed from what I changed it to on setup and matches what's specified in the admin console. This has to be something other than the base stations.
Is there any value in rebooting the 3cx server from the admin console?
I did upgrade the W70B firmware to the 3cx specific 146.88.0.10 version before setting up.
This is still an issue if anyone has any other suggestions. I did run the firewall test which came back all good.
Check that the IP isnt in 3CX blacklist.
If it was in blacklist and you enabled it to enabled, delete the entry completely.
The only IP in the Blacklist is one created when the system was installed. That one address is actually an allow, so a whitelist essentially.
Ok looks like the basics checks were done and the device is provisioned. I imagine you already added a few extension on it too correct?
You now need your 3CX Partner to help you run packet captures on the device, and learn what happens if and when it tries to register.
HaroonEtp
