Solved Deskphones no audio
RDWild
We just deployed several new deskphones on an existing system. They can call out, calls get answered, but we have no audio. When people call in, if we answer on several of these deskphones, we also cannot hear.
Hello RDWild,
The audio does go from the IP Phone to the 3CX Server and from the 3CX Server to the Sip Trunk Provider.
So the first thing to know for a fact is where the audio gets lost.
Can you call from one of the 'new' phones to another 'existing' and get audio (internal call)?
Or is it only to and from the SIP Trunk Provider where you have the problem (external call)?
Let's focus on the internal call failing.
How are the IP Phones connected to the 3CX server, is the 3CX Server local on the LAN?
Than focus on the used CODEC, this could be a problem ???
If the IP Phones are connected by a SBC on the LAN that is connected to the 3CX Server (cloud based), than focus on the SBC.
Also here there could be some codec problem.
Let start with some general question:
Type of 3CX server, like: Local, SMB, Pro Cloud?
Brand and type of phone used?
How is the phone connected to the 3CX server? SBC, STUN, LAN?
Paulo
Try enabling PBX delivers audio and see if that helps. It's under the option section on each user
All good. It was a phone firmware issue. Most of the phones were Fanvil X4U and were on too new a version of firmware.
Reactions: KyriacosS_3CX
For reference, these were X4U V2 phones, holding down the # key at startup puts the phone in recovery mode. To get to postmode, you have to reboot, wait until the power led turns on, off, then back on again, and then press # to get into postmode. That took way longer to figure out than it should have.
For future reference:
  • Reset instructions are here
  • Firmware instructions are here
Reactions: PaulC_3CX
x1515
