Diverts at different times
BND-KH
Hello All,
New here! Got a question from a customer and they would like to do divert to 2 different numbers depending on the day/time like so:
Monday - Saturday 7pm to 8am divert to External Number 1
Saturday 12.30pm to 4pm divert to External Number 2
4pm Saturday to Monday 8am divert to External Number 1
They would also like a message on it before it diverts as well.
Does anyone know how to do this - this is also not a PRO licensed install - and if so can anyone provide the instructions on how to do this.
Kyle
If you use a normal dedicated 3CX, you can use a dummy user with exceptions to do this.
Standard or Pro doesn't matter. However, note that the free Standard is going away and you will need to either buy a Pro license or go to StartUP.
Hello Concepts,
Thank you for this, would you have any pointers/guides on how to do this.
Also on that note of licensing, when does it change?
June. You should see a warning banner already in your Management Console.
See under Users > create a new one > Forwarding Rules > Exceptions:
Configure as wanted. Then, route the calls to that extension.
kanderson
