Domain 3cx.fr / on3cx.fr blocked
JulienI
domains 3cx.fr / on3cx.fr are blocked on registry nic.fr
Every PBX relying on these domains is down
Reactions: ZoLuSs
I can confirm, on3cx.fr is blocked.
Only available via IPv4 or IPv6.
Confirmed on whois :
[julien@julien-desktop ~]$ whois on3cx.fr %% %% This is the AFNIC Whois server. %% %% complete date format: YYYY-MM-DDThh:mm:ssZ %% %% Rights restricted by copyright. %% See https://www.afnic.fr/en/domain-names-and-support/everything-there-is-to-know-about-domain-names/find-a-domain-name-or-a-holder-using-whois/ %% %% domain: on3cx.fr status: BLOCKED eppstatus: serverRenewProhibited eppstatus: serverUpdateProhibited eppstatus: serverTransferProhibited eppstatus: serverDeleteProhibited eppstatus: serverRecoverProhibited eppstatus: serverHold hold: YES holder-c: WPPF130-FRNIC admin-c: TL23978-FRNIC tech-c: NG18537-FRNIC registrar: Hosting Concepts B.V. d/b/a Openprovider Expiry Date: 2028-11-14T08:49:34Z created: 2018-11-14T08:49:34Z last-update: 2023-11-12T07:37:15.610239Z source: FRNIC
I opened a support case
Julien
my3cx.fr also affected.
please open support tickets too if you can. The more they get, the fastest this issue may be solved.
All instances affected here....
Support ticket opened too.
Reactions: JulienI
All domains with .fr as extension are down
%% See https://www.afnic.fr/en/domain-name...s/find-a-domain-name-or-a-holder-using-whois/
domain: 3cx.fr
status: BLOCKED
hold: YES
Expiry Date: 2024-11-19T14:52:33Z
created: 2006-02-13T09:30:53Z
last-update: 2023-11-12T08:10:10.592712Z
source: FRNIC
Yes, all servers affected here too (both .on3cx.fr and .my3cx.fr)
Same here, all .fr FQDNs are down
Reactions: Yoann_Transacom
I confirm, same for all my clients. Everything who relies on FQDN is down.
Hoping someone has an emergency line to support?
Luckily it's the end of the day for most customers (still some of mine working late at night...), but it really has to be solved in the next few hours
same here, I regained access to the console defining the .my3cx.fr in my hosts file, but cant update all the phones !
We have clients who work 24/7
home hospitalization
Reactions: JulienCluzel
We are aware of the issue and are currently looking into it. It does not seem to be an issue on our side, but we are not ruling anything out at the moment. We are in touch with the domain registrar to check what may have happened.
Ok Thanks
Is it possible to have more information for the recovery time??
We need to know when AFNIC will be able to unblock your .fr domain names
please update
We have been informed that the issue does not just affect 3cx fr domains. As such, this is not directly related to 3cx fr but a broader problem with the fr domains; as such, we do not have any control over the issue and have no way of knowing any resolution times, I'm afraid.
This response it's crazy !
What is the procedure for changing the FQDN of a self-hosted 3CX installation and renewing LE certificates?
Reactions: MayurPatel
GP Concepts
